Introdução
To get to key parts of the computer, such as the disc drive and the motherboard, you will have to remove the two bottom panels of the computer. Once you have done this, you will be able to get to the innards of the computer for repairs or replacements. This guide will walk you through the steps of removing these panels.
O que você precisa
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Uma outra pessoa concluiu este guia.
