Introdução
This guide outlines the simple steps required to remove the disc drive from the computer. Simply do what the guide tells you, and the disc drive will easily come off the computer.
O que você precisa
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Uma outra pessoa concluiu este guia.
