Ir para o conteúdo principal
Samsung ST76 Motherboard Replacement
O que você precisa
  1. Samsung ST76 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Samsung ST76 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Samsung ST76 Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: passo 2, imagem 1 %32 Samsung ST76 Motherboard Replacement: passo 2, imagem 2 %32
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: passo 3, imagem 1 %32 Samsung ST76 Motherboard Replacement, Screen: passo 3, imagem 2 %32
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: passo 4, imagem 1 %32 Samsung ST76 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Samsung ST76 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Samsung ST76 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: passo 6, imagem 1 %32 Samsung ST76 Motherboard Replacement: passo 6, imagem 2 %32 Samsung ST76 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the 4 cables connecting the motherboard to the camera body.
Conclusão
Jessica Bain
Membro desde: 03/11/15
408 Reputação
Autoria de 2 guias
Equipe
Marist, Team 1-6, Laflen Spring 2015 Membro de Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
Membros da 2
Autoria de 8 guias
3 comentários
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Responder
Where can you buy a replacement motherboard?
Demaree Wiitala - Responder
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 925
