Introdução
This guide can be used to replace any damaged front panels, access the lens, and other inner parts of the camera.
O que você precisa
Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
Uma outra pessoa concluiu este guia.
