Ir para o conteúdo principal
Samsung ST150F Rear Panel Control Board Replacement
O que você precisa
  1. Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: passo 1, imagem 1 %32 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: passo 1, imagem 2 %32 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: passo 1, imagem 3 %32
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F Rear Panel Control Board Replacement: passo 2, imagem 1 %32
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F Rear Panel Control Board Replacement: passo 3, imagem 1 %32
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F Rear Panel Control Board Replacement: passo 4, imagem 1 %32
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F Rear Panel Control Board Replacement, Rear Panel Control Board: passo 5, imagem 1 %32
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F Rear Panel Control Board Replacement: passo 6, imagem 1 %32 Samsung ST150F Rear Panel Control Board Replacement: passo 6, imagem 2 %32 Samsung ST150F Rear Panel Control Board Replacement: passo 6, imagem 3 %32
    • Remove the Phillips head screws from the metal back plate.
  7. Samsung ST150F Rear Panel Control Board Replacement: passo 7, imagem 1 %32
    • Use the spudger to life the tab on the side of the metal plate.
  8. Samsung ST150F Rear Panel Control Board Replacement: passo 8, imagem 1 %32 Samsung ST150F Rear Panel Control Board Replacement: passo 8, imagem 2 %32
    • Pull gently on the control panel to remove it from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Eaton
Membro desde: 03/29/15
107 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-1, Shastany Spring 2015 Membro de UMass Dartmouth, Team 2-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G1
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 675
