Introdução
This guide will require a screwdriver with a Phillips #0 head (labeled PH0 in iFixit 54 bit driver kit) and a plastic opening tool. Be careful not to lose the small screws involved with removing this part of the device.
O que você precisa
Locate the arrow on the panel of the rear side of the phone.
Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
To reassemble your device, follow these instructions in reverse order. Be sure to secure the casing around the entire perimeter of the phone.
