Ir para o conteúdo principal
Samsung SPH-M360 Battery Replacement
  1. Samsung SPH-M360 Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung SPH-M360 Battery Replacement, Battery: passo 1, imagem 2 %32 Samsung SPH-M360 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Battery Replacement: passo 2, imagem 1 %32 Samsung SPH-M360 Battery Replacement: passo 2, imagem 2 %32 Samsung SPH-M360 Battery Replacement: passo 2, imagem 3 %32
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
Conclusão
To reassemble your device, follow these instructions in reverse order. Be sure to place the side of the battery showing two small arrows in first, with the arrows showing and pointing towards the bottom end of the phone.
Hunter Parker
Membro desde: 10/22/15
475 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 209
