Ir para o conteúdo principal
Samsung SPH-A760 Speakers Replacement
O que você precisa
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: passo 1, imagem 1 %32 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: passo 1, imagem 2 %32
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: passo 2, imagem 1 %32 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: passo 2, imagem 2 %32
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: passo 3, imagem 1 %32
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: passo 4, imagem 1 %32
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: passo 5, imagem 1 %32 Samsung SPH-A760 Speakers Replacement: passo 5, imagem 2 %32
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: passo 6, imagem 1 %32 Samsung SPH-A760 Speakers Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: passo 7, imagem 1 %32 Samsung SPH-A760 Speakers Replacement: passo 7, imagem 2 %32
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: passo 8, imagem 1 %32 Samsung SPH-A760 Speakers Replacement, Speakers: passo 8, imagem 2 %32
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: passo 9, imagem 1 %32 Samsung SPH-A760 Speakers Replacement: passo 9, imagem 2 %32 Samsung SPH-A760 Speakers Replacement: passo 9, imagem 3 %32
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: passo 10, imagem 1 %32 Samsung SPH-A760 Speakers Replacement: passo 10, imagem 2 %32 Samsung SPH-A760 Speakers Replacement: passo 10, imagem 3 %32
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Conclusão
David
Membro desde: 04/19/10
25 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 10-43, Garner Spring 2010 Membro de Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,951
