Ir para o conteúdo principal
Samsung SPH-A660 Keypad Replacement
O que você precisa
  1. Samsung SPH-A660 Keypad Replacement, Battery: passo 1, imagem 1 %32 Samsung SPH-A660 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone over so that it is face down.
  2. Samsung SPH-A660 Keypad Replacement: passo 2, imagem 1 %32 Samsung SPH-A660 Keypad Replacement: passo 2, imagem 2 %32 Samsung SPH-A660 Keypad Replacement: passo 2, imagem 3 %32
    • To remove the battery, push up with your finger on the tab located on the top center of the back of the phone.
    • Next, pull the battery off the back of the phone.
  3. Samsung SPH-A660 Keypad Replacement, Motherboard: passo 3, imagem 1 %32 Samsung SPH-A660 Keypad Replacement, Motherboard: passo 3, imagem 2 %32
    • Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
    • Bend back the antenna to access the indicated left middle screw in order to unscrew it.
    • Do not forget to unscrew the indicated screw on the top left corner of the phone. It will be difficult in further steps to take the phone apart if this screw is left in.
  4. Samsung SPH-A660 Keypad Replacement: passo 4, imagem 1 %32 Samsung SPH-A660 Keypad Replacement: passo 4, imagem 2 %32 Samsung SPH-A660 Keypad Replacement: passo 4, imagem 3 %32
    • Place the phone on its side.
    • Insert the small plastic opening tool into the slot that runs along the side of the phone.
    • Slowly pry open the phone by working your way around its edges with the opening tool.
    • There are tabs that run the entire length of the phone which hold the phone together. You may need a significant amount of force to pry the phone apart.
    • During this step, the side volume key may fall out; this is okay.
  5. Samsung SPH-A660 Keypad Replacement: passo 5, imagem 1 %32
    • Carefully lift the highlighted connector between the logic board and the screen by using either your fingers or a plastic opening tool as shown in the picture.
  6. Samsung SPH-A660 Keypad Replacement: passo 6, imagem 1 %32 Samsung SPH-A660 Keypad Replacement: passo 6, imagem 2 %32 Samsung SPH-A660 Keypad Replacement: passo 6, imagem 3 %32
    • Remove the green logic board from the phone by gently lifting it up with the plastic opening tool. Be cautious to not break the logic board.
    • The keypad may fall out, this is okay. Set it aside.
  7. Samsung SPH-A660 Keypad Replacement, Keypad: passo 7, imagem 1 %32 Samsung SPH-A660 Keypad Replacement, Keypad: passo 7, imagem 2 %32 Samsung SPH-A660 Keypad Replacement, Keypad: passo 7, imagem 3 %32
    • Remove the keypad from the body by grasping the white rubbery pad and lifting it off the phone.
  8. Samsung SPH-A660 Keypad Replacement: passo 8, imagem 1 %32 Samsung SPH-A660 Keypad Replacement: passo 8, imagem 2 %32
    • Remove the dirt and grime that may accumulate under the keypad by using an air can or in this case, a brush.
    • Once you have cleaned out the keypad, follow these steps in reverse to reassemble your phone.
Conclusão
Mike Buerli
Membro desde: 01/22/10
4 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-26, Maness Winter 2010 Membro de Cal Poly, Team 13-26, Maness Winter 2010
CPSU-MANESS-W10S13G26
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 32
Ao todo: 2,429
