Ir para o conteúdo principal
Samsung SPH-A500 Speaker Replacement
O que você precisa
  1. Samsung SPH-A500 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: passo 2, imagem 1 %32
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: passo 3, imagem 1 %32
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: passo 4, imagem 1 %32
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: passo 7, imagem 1 %32
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Dominikovic
Membro desde: 04/13/10
139 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-100, Johann Spring 2010 Membro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 2,409
