Ir para o conteúdo principal
Samsung SPH-A500 Logic Board Replacement
O que você precisa
  1. Samsung SPH-A500 Logic Board Replacement, Logic Board: passo 1, imagem 1 %32
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Logic Board Replacement: passo 2, imagem 1 %32
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Logic Board Replacement: passo 3, imagem 1 %32
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Logic Board Replacement: passo 4, imagem 1 %32
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Logic Board Replacement: passo 5, imagem 1 %32
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  6. Samsung SPH-A500 Logic Board Replacement: passo 6, imagem 1 %32
    • Look for the clip at the top right corner of the logic board.
  7. Samsung SPH-A500 Logic Board Replacement: passo 7, imagem 1 %32
    • Remove the clip from the logic board.
  8. Samsung SPH-A500 Logic Board Replacement: passo 8, imagem 1 %32
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Dominikovic
Membro desde: 04/13/10
139 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-100, Johann Spring 2010 Membro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,069
