Ir para o conteúdo principal
Samsung SPH-A500 Keypad Replacement
O que você precisa
  1. Samsung SPH-A500 Keypad Replacement, Keypad: passo 1, imagem 1 %32
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Samsung SPH-A500 Keypad Replacement: passo 2, imagem 1 %32
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung SPH-A500 Keypad Replacement: passo 3, imagem 1 %32
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
    Pergunte ao FixBot
    Comentar
  4. Samsung SPH-A500 Keypad Replacement: passo 4, imagem 1 %32
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
    Pergunte ao FixBot
    Comentar
  5. Samsung SPH-A500 Keypad Replacement: passo 5, imagem 1 %32
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    Pergunte ao FixBot
    Comentar
  6. Samsung SPH-A500 Keypad Replacement: passo 6, imagem 1 %32
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
    Pergunte ao FixBot
    Comentar
  7. Samsung SPH-A500 Keypad Replacement: passo 7, imagem 1 %32
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
    Pergunte ao FixBot
    Comentar
  8. Samsung SPH-A500 Keypad Replacement: passo 8, imagem 1 %32
    • Replace the keypad.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 18-100, Johann Spring 2010 Membro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 40
Ao todo: 2,099
