Ir para o conteúdo principal
Samsung SPH-A500 Front LCD Display Replacement
O que você precisa
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: passo 1, imagem 1 %32
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: passo 3, imagem 1 %32
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: passo 4, imagem 1 %32
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: passo 5, imagem 1 %32
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: passo 6, imagem 1 %32
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: passo 7, imagem 1 %32
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Conclusão
Equipe
Cal Poly, Team 18-100, Johann Spring 2010 Membro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 84
Ao todo: 2,789
