Ir para o conteúdo principal
Samsung SPEX SCH-R210 Back Cover Replacement
  1. Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
Conclusão
Austin
Membro desde: 07/11/13
201 Reputação
Autoria de 2 guias
Equipe
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membros
Autoria de 10 guias
1Comentário do guia
uh, this is so easy that I’m pretty sure it doesn’t need a guide for it. I found an old Spex (perfect condition except for a few flaws) and I knew how to take off the cover from day 1, but it’s nice you made this anyway. Thx ig
Isaac Kassahun - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 45
Ao todo: 411
