Ir para o conteúdo principal
Samsung SGH-X495 Face Plate Replacement
O que você precisa
  1. Samsung SGH-X495 Face Plate Replacement, Face Plate: passo 1, imagem 1 %32
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Samsung SGH-X495 Face Plate Replacement: passo 2, imagem 1 %32
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. Samsung SGH-X495 Face Plate Replacement: passo 3, imagem 1 %32 Samsung SGH-X495 Face Plate Replacement: passo 3, imagem 2 %32
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  4. Samsung SGH-X495 Face Plate Replacement: passo 4, imagem 1 %32 Samsung SGH-X495 Face Plate Replacement: passo 4, imagem 2 %32
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  5. Samsung SGH-X495 Face Plate Replacement: passo 5, imagem 1 %32 Samsung SGH-X495 Face Plate Replacement: passo 5, imagem 2 %32
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
Conclusão
Matthew Hove
Membro desde: 01/05/11
1.031 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 3-40, Regan Winter 2011 Membro de Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,092
