Ir para o conteúdo principal
Samsung SGH-X495 Backplate Replacement
O que você precisa
  1. Samsung SGH-X495 Backplate Replacement, Battery: passo 1, imagem 1 %32 Samsung SGH-X495 Backplate Replacement, Battery: passo 1, imagem 2 %32
    • Use thumb nail to release the white hook; then use fingertip to pry the battery loose starting from the top.
    • Second photo gives a view from the back of the phone and battery.
  2. Samsung SGH-X495 Backplate Replacement, Backplate: passo 2, imagem 1 %32
    • Remove the 4 (4.7mm) philips head screws.
  3. Samsung SGH-X495 Backplate Replacement: passo 3, imagem 1 %32
    • Unplug the rubber charger outlet cover.
  4. Samsung SGH-X495 Backplate Replacement: passo 4, imagem 1 %32
    • Unplug the rubber headset jack cover.
  5. Samsung SGH-X495 Backplate Replacement: passo 5, imagem 1 %32 Samsung SGH-X495 Backplate Replacement: passo 5, imagem 2 %32
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  6. Samsung SGH-X495 Backplate Replacement: passo 6, imagem 1 %32 Samsung SGH-X495 Backplate Replacement: passo 6, imagem 2 %32
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
Conclusão
Matthew Hove
Membro desde: 01/05/11
1.031 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 3-40, Regan Winter 2011 Membro de Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 1,262
