Ir para o conteúdo principal
Samsung SGH-X105 Earpiece Speaker Replacement
O que você precisa
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, imagem 1 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, imagem 2 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, imagem 3 %32
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: passo 3, imagem 1 %32
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, imagem 1 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, imagem 2 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, imagem 3 %32
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: passo 5, imagem 1 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 5, imagem 2 %32
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: passo 6, imagem 1 %32
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, imagem 1 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, imagem 2 %32 Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, imagem 3 %32
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Lao
Membro desde: 04/15/10
16 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 28-29, Regan Spring 2010 Membro de Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
Membros da 4
Autoria de 12 guias
Um comentário
Where can I get a replacement speaker?
NickyPhils - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,940
