Ir para o conteúdo principal
Samsung SGH-T639 Volumn Button Replacement
O que você precisa
  1. Samsung SGH-T639 Volumn Button Replacement, Battery: passo 1, imagem 1 %32
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Volumn Button Replacement: passo 2, imagem 1 %32
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Volumn Button Replacement, SIM Card: passo 3, imagem 1 %32 Samsung SGH-T639 Volumn Button Replacement, SIM Card: passo 3, imagem 2 %32 Samsung SGH-T639 Volumn Button Replacement, SIM Card: passo 3, imagem 3 %32
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Volumn Button Replacement, Volumn Button: passo 4, imagem 1 %32 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: passo 4, imagem 2 %32 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: passo 4, imagem 3 %32
    • Locate the six (4mm) screws on the back of the phone.
    • Unscrew all six screws using a Phillips head #000 screwdriver.
  5. Samsung SGH-T639 Volumn Button Replacement: passo 5, imagem 1 %32 Samsung SGH-T639 Volumn Button Replacement: passo 5, imagem 2 %32 Samsung SGH-T639 Volumn Button Replacement: passo 5, imagem 3 %32
    • Locate volume button.
    • Starting at the top, pry the back casing of the phone.
    • Continue prying around the side of the phone. Being careful around the volume button.
  6. Samsung SGH-T639 Volumn Button Replacement: passo 6, imagem 1 %32 Samsung SGH-T639 Volumn Button Replacement: passo 6, imagem 2 %32 Samsung SGH-T639 Volumn Button Replacement: passo 6, imagem 3 %32
    • Remove back casing from the phone.
    • Relocate the volume button.
    • Gently push the volume button towards the interior of the back casing of the phone.
  7. Samsung SGH-T639 Volumn Button Replacement: passo 7, imagem 1 %32
    • Completely remove the volume button from the cell phone.
Conclusão
Yi Ren
Membro desde: 03/26/14
801 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 1-4, Benson Spring 2014 Membro de Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 177
