Introdução
This guide contains photos that do not include pictures of the back cover or battery. However, the instructions have been adjusted to reflect this lack of visual aid.
Peças
Não são necessárias peças.
  1. Flip the phone over and take off the back cover
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Use button to remove battery from the phone.
    • Use button to remove battery from the phone.
  3. Locate SIM card Slide SIM card down and gently pull out of the card slot Slide SIM card down and gently pull out of the card slot
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Locate the six (4mm) screws on the back of the phone. Unscrew all six screws using a Phillips head #000 screwdriver. Unscrew all six screws using a Phillips head #000 screwdriver.
    • Locate the six (4mm) screws on the back of the phone.
    • Unscrew all six screws using a Phillips head #000 screwdriver.
  6. Locate volume button. Starting at the top, pry the back casing of the phone. Continue prying around the side of the phone. Being careful around the volume button.
    • Locate volume button.
    • Starting at the top, pry the back casing of the phone.
    • Continue prying around the side of the phone. Being careful around the volume button.
  7. Remove back casing from the phone. Relocate the volume button. Gently push the volume button towards the interior of the back casing of the phone.
    • Remove back casing from the phone.
    • Relocate the volume button.
    • Gently push the volume button towards the interior of the back casing of the phone.
  8. Completely remove the volume button from the cell phone.
    • Completely remove the volume button from the cell phone.
Conclusão
Yi Ren
801 reputação
8 Guides authored
Equipe
Clemson, Team 1-4, Benson Spring 2014 Membro de Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 Membros
16 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 95
