Introdução
The screen is connected to a circuit board. These two pieces will be removed as one unit. Do not try and disconnect the circuit board from the screen.
O que você precisa
Flip phone over and locate the screw covers.
Remove the two thin screw covers using the tweezers.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Locate the two screws (3mm) at the base of the top portion of the cell phone.
Remove screws using a phillips head #000 screwdriver.
Place screws on magnetic mat.
Quase terminado!
Conclusão
