Ir para o conteúdo principal
Samsung SGH-E317 Motherboard Replacement
O que você precisa
  1. Samsung SGH-E317 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: passo 2, imagem 1 %32
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: passo 4, imagem 1 %32
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: passo 5, imagem 1 %32
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: passo 6, imagem 1 %32
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: passo 7, imagem 1 %32 Samsung SGH-E317 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: passo 8, imagem 1 %32 Samsung SGH-E317 Motherboard Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: passo 9, imagem 1 %32 Samsung SGH-E317 Motherboard Replacement: passo 9, imagem 2 %32
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Conclusão
Chris Dimler
Membro desde: 01/22/11
124 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-23, Maness Winter 2011 Membro de Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,416
