Ir para o conteúdo principal
Samsung SGH-A237 Logic Board Replacement
O que você precisa
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Samsung SGH-A237 Logic Board Replacement, Logic Board: passo 1, imagem 2 %32
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: passo 2, imagem 1 %32 Samsung SGH-A237 Logic Board Replacement: passo 2, imagem 2 %32
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: passo 3, imagem 1 %32 Samsung SGH-A237 Logic Board Replacement: passo 3, imagem 2 %32
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: passo 4, imagem 1 %32 Samsung SGH-A237 Logic Board Replacement: passo 4, imagem 2 %32 Samsung SGH-A237 Logic Board Replacement: passo 4, imagem 3 %32
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: passo 5, imagem 1 %32
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: passo 6, imagem 1 %32 Samsung SGH-A237 Logic Board Replacement: passo 6, imagem 2 %32
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Conclusão
Equipe
Cal Poly, Team 29-81, Johann Spring 2010 Membro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,839
