Introdução
This repair guide shows how to remove and replace the logic board.
Peças
Não são necessárias peças.
  1. Put the phone face down so that the battery cover is showing. Put the phone face down so that the battery cover is showing.
    • Put the phone face down so that the battery cover is showing.
  2. Use your thumb to push the cover down and off. Lift the battery off the device.
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown. Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  5. Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device. Note: some force must be applied when removing back cover. Note: some force must be applied when removing back cover.
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  6. Detach the tab from the logic board by using iPod Opening Tool (as shown).
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  7. Use iPod Opening Tool to lift the green logic board carefully. Remove logic board from the device and replace with new one.
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Conclusão
Theodore Johansen
1 reputação
2 Guides authored
Equipe
Cal Poly, Team 29-81, Johann Spring 2010 Membro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Membros
8 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Todo: 2,699
