Ir para o conteúdo principal
Samsung SGH-A237 Keypad Replacement
O que você precisa
  1. Samsung SGH-A237 Keypad Replacement, Keypad: passo 1, imagem 1 %32 Samsung SGH-A237 Keypad Replacement, Keypad: passo 1, imagem 2 %32
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: passo 2, imagem 1 %32 Samsung SGH-A237 Keypad Replacement: passo 2, imagem 2 %32
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: passo 3, imagem 1 %32 Samsung SGH-A237 Keypad Replacement: passo 3, imagem 2 %32
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: passo 4, imagem 1 %32 Samsung SGH-A237 Keypad Replacement: passo 4, imagem 2 %32 Samsung SGH-A237 Keypad Replacement: passo 4, imagem 3 %32
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: passo 5, imagem 1 %32
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: passo 6, imagem 1 %32 Samsung SGH-A237 Keypad Replacement: passo 6, imagem 2 %32
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: passo 7, imagem 1 %32
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Conclusão
Shawn
Membro desde: 04/14/10
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 29-81, Johann Spring 2010 Membro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
Membros da 4
Autoria de 8 guias
Um comentário
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,303
