Introdução
With this guide you can clean or repair a faulty keypad.
Peças
Não são necessárias peças.
  1. Place phone face down so battery cover is showing. Place phone face down so battery cover is showing.
    • Place phone face down so battery cover is showing.
  2. Use thumb to push the cover down and off. Lift battery cover off the device.
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown. Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device. Some force must be applied, and the back cover should come off. Some force must be applied, and the back cover should come off.
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  6. Detach the tab from the logic board shown by using the Ipod Opening Tool
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  7. Use the Ipod Opening Tool to lift the green logic board carefully. Remove the logic board from the device.
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  8. The keypad should peel off the logic board with a gentle pull.
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Conclusão
Shawn
1 reputação
2 Guides authored
Equipe
Cal Poly, Team 29-81, Johann Spring 2010 Membro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Membros
8 Guides authored
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 2,258
