Ir para o conteúdo principal
Samsung SGH-A137 Keypad Replacement
O que você precisa
  1. Samsung SGH-A137 Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Keypad Replacement: passo 2, imagem 1 %32
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, imagem 1 %32 Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, imagem 2 %32 Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, imagem 3 %32
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Keypad Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Keypad Replacement: passo 5, imagem 1 %32 Samsung SGH-A137 Keypad Replacement: passo 5, imagem 2 %32
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Keypad Replacement: passo 6, imagem 1 %32
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
  7. Samsung SGH-A137 Keypad Replacement, Keypad: passo 7, imagem 1 %32
    • Gently push the keypad out toward the back.
  8. Samsung SGH-A137 Keypad Replacement: passo 8, imagem 1 %32
    • Replace the defective keypad and reassemble the phone.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 47
Ao todo: 562
