Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung SGH-A117, use o nosso manual de serviço.
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: passo 1, imagem 1 %32
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: passo 2, imagem 1 %32
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: passo 3, imagem 1 %32
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: passo 4, imagem 1 %32 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: passo 4, imagem 2 %32
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: passo 5, imagem 1 %32
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: passo 6, imagem 1 %32 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: passo 6, imagem 2 %32
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: passo 7, imagem 1 %32 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: passo 7, imagem 2 %32
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: passo 8, imagem 1 %32
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
Membro desde: 10/06/14
150 Reputação
Autoria de 2 guias
Equipe
Aristotle Membro de Aristotle
Community
Membros da 5
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 889
