Ir para o conteúdo principal
Samsung SCV-VLUUST50 Shutter Button Replacement
O que você precisa
  1. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: passo 1, imagem 1 %32 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: passo 1, imagem 2 %32 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: passo 1, imagem 3 %32
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Shutter Button Replacement: passo 2, imagem 1 %32 Samsung SCV-VLUUST50 Shutter Button Replacement: passo 2, imagem 2 %32 Samsung SCV-VLUUST50 Shutter Button Replacement: passo 2, imagem 3 %32
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Shutter Button Replacement: passo 3, imagem 1 %32
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Shutter Button Replacement: passo 4, imagem 1 %32 Samsung SCV-VLUUST50 Shutter Button Replacement: passo 4, imagem 2 %32
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: passo 5, imagem 1 %32 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: passo 5, imagem 2 %32 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: passo 5, imagem 3 %32
    • Remove the screw below the shutter button with a Phillips #000 screw driver.
    • Once the screw is removed the shutter button should easily come off, and you can replace it with the new button.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 304
