Ir para o conteúdo principal
Samsung SCV-VLUUST50 Screen Replacement
O que você precisa
  1. Samsung SCV-VLUUST50 Screen Replacement, Cover: passo 1, imagem 1 %32 Samsung SCV-VLUUST50 Screen Replacement, Cover: passo 1, imagem 2 %32 Samsung SCV-VLUUST50 Screen Replacement, Cover: passo 1, imagem 3 %32
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Screen Replacement: passo 2, imagem 1 %32 Samsung SCV-VLUUST50 Screen Replacement: passo 2, imagem 2 %32 Samsung SCV-VLUUST50 Screen Replacement: passo 2, imagem 3 %32
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Screen Replacement: passo 3, imagem 1 %32
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Screen Replacement: passo 4, imagem 1 %32 Samsung SCV-VLUUST50 Screen Replacement: passo 4, imagem 2 %32
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Screen Replacement, Screen: passo 5, imagem 1 %32 Samsung SCV-VLUUST50 Screen Replacement, Screen: passo 5, imagem 2 %32 Samsung SCV-VLUUST50 Screen Replacement, Screen: passo 5, imagem 3 %32
    • Open the ribbon connector with your fingernail.
    • Pull the ribbon out of the connection.
  6. Samsung SCV-VLUUST50 Screen Replacement: passo 6, imagem 1 %32
    • Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
    • Feed the new screen's ribbon through the same slot it came out of.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 125
