Ir para o conteúdo principal
Samsung SCH-U340 Lower Casing Replacement
O que você precisa
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: passo 1, imagem 1 %32
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: passo 2, imagem 1 %32
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: passo 3, imagem 1 %32
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: passo 4, imagem 1 %32
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: passo 5, imagem 1 %32 Samsung SCH-U340 Lower Casing Replacement: passo 5, imagem 2 %32
    • Use a spudger to pry the back assembly off of the device.
Conclusão
Equipe
Cal Poly, Team 3-21, Maness Winter 2010 Membro de Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,606
