Introdução
This guide will teach you how to remove your Samsung SCH-A950's logic board.
O que você precisa
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Remove the four Phillips #00 screws underneath the battery.
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
Using a plastic opening tool, disconnect the display cable from the motherboard.
