Ir para o conteúdo principal
Introdução
The Keypad may get worn or dirty as time goes by. This guide will aid in the removal of the keypad for cleaning or replacement.
Peças
Nenhum componente especificado.
  1. Samsung SCH-A670 Keypad Replacement, Battery Cover: passo 1, imagem 1 %32
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Keypad Replacement, Battery: passo 2, imagem 1 %32
    • Remove the battery.
  3. Samsung SCH-A670 Keypad Replacement, Logic Board: passo 3, imagem 1 %32
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Keypad Replacement: passo 4, imagem 1 %32
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Keypad Replacement: passo 5, imagem 1 %32
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Keypad Replacement: passo 6, imagem 1 %32 Samsung SCH-A670 Keypad Replacement: passo 6, imagem 2 %32
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Keypad Replacement: passo 7, imagem 1 %32
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Keypad Replacement: passo 8, imagem 1 %32
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Keypad Replacement, Keypad: passo 9, imagem 1 %32
    • Once the logic board has been removed, peel the keypad up.
Conclusão
Nathan Brink
Membro desde: 11/04/2010
19 Reputação
7 Guias de autoria
Cal Poly, Team 34-59, Forte Spring 2010 Membro de Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Membros
14 Guias de autoria
0 Comments
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,514
