Introdução
The keypad may become broken over time, this guide will assist in the replacement of the keypad.
Peças
Não são necessárias peças.
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
Quase terminado!
Conclusão
