Ir para o conteúdo principal
Samsung SCH-A670 Camera Replacement
O que você precisa
  1. Samsung SCH-A670 Camera Replacement, Battery Cover: passo 1, imagem 1 %32
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Camera Replacement, Battery: passo 2, imagem 1 %32
    • Remove the battery.
  3. Samsung SCH-A670 Camera Replacement, Logic Board: passo 3, imagem 1 %32
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Camera Replacement: passo 4, imagem 1 %32
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Camera Replacement: passo 5, imagem 1 %32
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Camera Replacement: passo 6, imagem 1 %32 Samsung SCH-A670 Camera Replacement: passo 6, imagem 2 %32
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Camera Replacement: passo 7, imagem 1 %32
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Camera Replacement: passo 8, imagem 1 %32
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Camera Replacement, Keypad: passo 9, imagem 1 %32
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Camera Replacement, Keypad Housing: passo 10, imagem 1 %32 Samsung SCH-A670 Camera Replacement, Keypad Housing: passo 10, imagem 2 %32
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Camera Replacement, Screen Casing: passo 11, imagem 1 %32
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Camera Replacement: passo 12, imagem 1 %32
    • Carefully pry apart the casing with the spudger tool.
  13. Samsung SCH-A670 Camera Replacement, Screen: passo 13, imagem 1 %32
    • Use the spudger to carefully pry off the speaker.
  14. Samsung SCH-A670 Camera Replacement: passo 14, imagem 1 %32
    • Carefully pry off the ringer with the spudger.
  15. Samsung SCH-A670 Camera Replacement: passo 15, imagem 1 %32
    • Carefully pry off the screen with the spudger.
  16. Samsung SCH-A670 Camera Replacement, Camera: passo 16, imagem 1 %32
    • Gently pry off the camera with the spudger.
Conclusão
Nathan Brink
Membro desde: 04/11/10
19 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 34-59, Forte Spring 2010 Membro de Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Membros
14 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 4,103
