Ir para o conteúdo principal
Samsung SCH-8500 Volume Button Replacement
O que você precisa
  1. Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, imagem 1 %32 Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, imagem 2 %32 Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, imagem 3 %32
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, imagem 1 %32 Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, imagem 2 %32 Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, imagem 1 %32 Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, imagem 2 %32 Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, imagem 3 %32
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
Conclusão
Will Gunter
Membro desde: 10/23/12
1 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 14-6, Benson Fall 2012 Membro de Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 44
Ao todo: 414
