Ir para o conteúdo principal
Samsung SCH-3500 Antenna Replacement
  1. Samsung SCH-3500 Antenna Replacement, Battery: passo 1, imagem 1 %32 Samsung SCH-3500 Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
  2. Samsung SCH-3500 Antenna Replacement: passo 2, imagem 1 %32
    • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
  3. Samsung SCH-3500 Antenna Replacement: passo 3, imagem 1 %32
    • Lift the battery away from the phone case.
  4. Samsung SCH-3500 Antenna Replacement, Antenna: passo 4, imagem 1 %32 Samsung SCH-3500 Antenna Replacement, Antenna: passo 4, imagem 2 %32
    • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
  5. Samsung SCH-3500 Antenna Replacement: passo 5, imagem 1 %32
    • When unscrewed, pull the antenna straight up and out.
  6. Samsung SCH-3500 Antenna Replacement: passo 6, imagem 1 %32 Samsung SCH-3500 Antenna Replacement: passo 6, imagem 2 %32
    • Pull the guide tube free from its retaining ring and slide it out the top.
Conclusão
Equipe
Clemson, Team 2-6, Benson Spring 2012 Membro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 719
