Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
You will take the camera apart in order to replace the damaged LCD screen and restore functionality.
O que você precisa
Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
Carefully pull the back case (the side showing the LCD screen) away from the front half.
There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
Turn the camera around to the front (the lens side). Carefully remove the front case.
There are also clips on the lens' side as well, so do not be afraid to use force.
3 outras pessoas executaram este guia.
