Ir para o conteúdo principal
Samsung S760 Front and Back Case Replacement Guide
O que você precisa
  1. Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, imagem 1 %32 Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, imagem 2 %32 Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, imagem 3 %32
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Front and Back Case Replacement Guide: passo 2, imagem 1 %32 Samsung S760 Front and Back Case Replacement Guide: passo 2, imagem 2 %32
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, imagem 1 %32 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, imagem 2 %32 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, imagem 3 %32
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Front and Back Case Replacement Guide: passo 4, imagem 1 %32 Samsung S760 Front and Back Case Replacement Guide: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Front and Back Case Replacement Guide: passo 5, imagem 1 %32
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
Conclusão
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
David Sepulveda
Membro desde: 03/06/17
551 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 677
