Ir para o conteúdo principal
Samsung Rogue Speaker/Antenna Replacement
O que você precisa
  1. Samsung Rogue Speaker/Antenna Replacement, Battery: passo 1, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Speaker/Antenna Replacement: passo 2, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement: passo 2, imagem 2 %32
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Speaker/Antenna Replacement, Motherboard: passo 3, imagem 1 %32
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Speaker/Antenna Replacement: passo 4, imagem 1 %32
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Speaker/Antenna Replacement: passo 5, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement: passo 5, imagem 2 %32 Samsung Rogue Speaker/Antenna Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Speaker/Antenna Replacement: passo 6, imagem 1 %32
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Speaker/Antenna Replacement: passo 7, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement: passo 7, imagem 2 %32
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Speaker/Antenna Replacement: passo 8, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Speaker/Antenna Replacement, Speaker/Antenna: passo 9, imagem 1 %32
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Speaker/Antenna Replacement: passo 10, imagem 1 %32 Samsung Rogue Speaker/Antenna Replacement: passo 10, imagem 2 %32 Samsung Rogue Speaker/Antenna Replacement: passo 10, imagem 3 %32
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
Conclusão
Equipe
Cal Poly, Team 7-32, Maness Spring 2012 Membro de Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 367
