Introdução
This guide shows how to remove and replace the fuse block or fuse board in your Samsung refrigerator.
The fuse block contains a number of fuses soldered on a circuit board and is made to be replaced as a whole unit. If your refrigerator doesn't power on at all, you may need to replace the fuse block.
This guide will work for most Samsung Refrigerators. This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Remove the screws securing the board access panel to the back of the refrigerator.
Squeeze the wide sides of the red connector to unlatch it from the fuse block.
Pull to disconnect the connector.
Repeat the procedure to disconnect the blue connector.
Repair didn’t go as planned? Ask our Answers Community for help.
Uma outra pessoa concluiu este guia.
