Introdução
If you have noticed water leakage inside your Samsung Refrigerator, and you don’t know where it came from, you likely have an ice buildup in the draining well. It is likely that the old evaporating clip is not doing justice and caused an ice buildup which led to the leakage.
If you notice leakage, it is important to complete this replacement as soon as possible. Water leakage in places with electronic components can cause your refrigerator to short out and can even lead to fires.
This fix does not require any special skills. As long as you follow the guide with all safety precautions, you will be able to perform a successful replacement of the evaporating clip in your Samsung Refrigerator.
Be sure to unplug and empty the refrigerator before disassembling.
O que você precisa
7 outras pessoas executaram este guia.
3 comentários
you rock!!!@
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
