Ir para o conteúdo principal
Samsung Refrigerator Evaporator Drain Clip Replacement
O que você precisa
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: passo 1, imagem 1 %32 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: passo 1, imagem 2 %32 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: passo 1, imagem 3 %32
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 2, imagem 1 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 2, imagem 2 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 2, imagem 3 %32
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 3, imagem 1 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 3, imagem 2 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 3, imagem 3 %32
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 4, imagem 1 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 4, imagem 2 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 4, imagem 3 %32
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 5, imagem 1 %32
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 6, imagem 1 %32
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: passo 7, imagem 1 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 7, imagem 2 %32 Samsung Refrigerator Evaporator Drain Clip Replacement: passo 7, imagem 3 %32
    • Replace the old clip with a new evaporating clip.
Conclusão
7 outras pessoas executaram este guia.
Deep Patel
Membro desde: 09/15/20
299 Reputação
Autoria de 1 guia
Equipe
3 comentários
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Responder
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 72
Últimos 30 dias: 330
Duração total: 15,445
