Ir para o conteúdo principal
Samsung Refrigerator Door Sensors Replacement
O que você precisa
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: passo 2, imagem 1 %32
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: passo 3, imagem 1 %32
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: passo 4, imagem 1 %32 Samsung Refrigerator Door Sensors Replacement: passo 4, imagem 2 %32
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: passo 5, imagem 1 %32
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: passo 6, imagem 1 %32 Samsung Refrigerator Door Sensors Replacement, Sensor information: passo 6, imagem 2 %32
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: passo 7, imagem 1 %32 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: passo 7, imagem 2 %32
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: passo 8, imagem 1 %32 Samsung Refrigerator Door Sensors Replacement: passo 8, imagem 2 %32
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: passo 9, imagem 1 %32
    • Remove the door sensor.
Conclusão
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 574 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 89
Últimos 30 dias: 425
Duração total: 2,759
