Introdução
This guide shows how to remove and replace the control panel in your Samsung refrigerator.
The control panel contains the buttons to change the refrigerator settings, as well as a display for current settings. The panel can become damaged and inoperative from prolonged moisture exposure.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Insert a spudger into the seam along the right edge of the control panel.
Press the spudger in firmly and pry to loosen the panel.
Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
Repair didn’t go as planned? Ask our Answers Community for help.
