Introdução
This guide shows how to remove and replace the control board in your Samsung refrigerator.
The control board controls the refrigerator's functions. It also has a DC power board built into it. If your refrigerator turns on but doesn't function properly, check the components related to the function first. Replace the control board only after you've verified the other components.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
O que você precisa
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Remove the screws securing the board access panel to the back of the refrigerator.
Three connectors along the top edge
One connector along the right edge
One connector along the bottom edge
Four connectors along the left edge
Pull and disconnect each of the connectors from the control board.
Move the wires away from the control board so it can swing out of its recess.
Repair didn’t go as planned? Ask our Answers Community for help.
5Comentários do guia
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
