Ir para o conteúdo principal
Samsung Rant Rear Case Replacement
O que você precisa
  1. Samsung Rant Rear Case Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: passo 3, imagem 1 %32
    • Gently separate the rear case from the front case.
Conclusão
Denise Cooper
Membro desde: 10/18/11
31 Reputação
Autoria de 3 guias
Equipe
James Madison, Team 1-6, Allen Fall 2011 Membro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,152
