Pular para o conteúdo principal
Introdução
In some cases, the motherboard of a device may stop working due to installment issues or a short circuit. Either way, we have created a user-friendly guide that will show you how to fix your device
Peças
Nenhum componente especificado.
  1. Start by removing the back plate and battery of the phone.
    • Start by removing the back plate and battery of the phone.
  2. Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device. Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
    • Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  4. Remove the casing from the back of the device. Remove the casing from the back of the device.
    • Remove the casing from the back of the device.
  5. Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad. Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
    • Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
  6. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
    • Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
Conclusão
Katelynn Lee
Membro desde: 18-10-2011
1 reputação
Autoria de 1 guia
Equipe
James Madison, Team 1-6, Allen Fall 2011 Membro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Membros
12 Guias de autoria
Est ce que ce téléphone a une puce ?
Allassane Diawara - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 4,087
