Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the phone over in the palm of your hand, with the screen facing down.
While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
You should now be able to lift the plate completely off of the phone.
Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
Using a pair of tweezers, grip the keypad gently.
Lift the keypad out of the phone and replace it (if necessary).
