Ir para o conteúdo principal
Samsung Rant Battery Replacement
  1. Samsung Rant Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Battery Replacement, Battery: passo 2, imagem 1 %32
    • Carefully remove the battery from the phone.
Conclusão
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Todd
Membro desde: 10/18/11
1 Reputação
Autoria de 1 guia
Equipe
James Madison, Team 1-6, Allen Fall 2011 Membro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
Membros da 4
Autoria de 12 guias
Um comentário
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,466
