Ir para o conteúdo principal
Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement
O que você precisa
  1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 1 %32 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 2 %32 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 3 %32
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: passo 2, imagem 1 %32
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: passo 3, imagem 1 %32 Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: passo 3, imagem 2 %32
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: passo 4, imagem 1 %32
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: passo 5, imagem 1 %32
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Fadi Alzammar
Membro desde: 04/22/18
782 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S25-G18, Maness Spring 2018 Membro de Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 257
